Thread: Retrive Data via Bacnet/IP protocol
    09.06.2015
    2
    Default Retrive Data via Bacnet/IP protocol
    Dear Sir,
    Currently we are doing some testing trying to retrieve data from Digital Power Meter (Modbus) via Bacnet/IP. Somehow, we unable to retrieve the data like voltage or current. How are going configure our driver configuration and the variable setting?
    Timothy
    (Eetarp Malaysia)
    09.06.2015
    2
    Default Re: Retrive Data via Bacnet/IP protocol
    Quote Originally Posted by eetarpmalaysia View Post
    Dear Sir,
    Timothy
    (Eetarp Malaysia)
    Dear Sir,
    Sorry for missing some information. At site the DPM was connected to Sitelink via modbus, then Sitelink connected to SiteGate-E via Bacnet, lastly from SiteGate became bacnet/TCP/IP. We really need help on this issues. As for variable, should we use Driver variable or property and how about the net address? Attached below image might be help a lot.
    Network Topology
    Devices trace using wago bacnet configuration software
    device list import using zenon driver configuration. device570010 add 11(hex) or 17(dec).
    sitelink (device570010)
    DPM & Bacnet Points
    Thanks.
    Timothy
    105
    Hi Timothy,
    Generally, the address and variable configuration can be done automaticly by importing the devices to the Driver configuration. The variables for the database can be browsed online from the device. This sets all needed properties of the variable / the datatag.
    What I see in one screenshot you post above, that you have more than one BACnet Driver in your Project.
    Please be Aware that you coose a different network card for each driver. Because the Driver is opening a listening port (47808) of course it can only opened once.
    Hope this helps,
    Markus
    11.06.2013
    32
    Lächeln Re: Retrive Data via Bacnet/IP protocol
    Hi!
    Please check the following hints:
    1.) Change the Max. concurrent requests from 50 to 10 and test it
    2.) Change the APDU timeouts to
    APDU timeout 5000 and APDU retries to 5
    br steph
  1. Bacnet Anbindung
    By and12121 in forum Drivers
    Last Post: 16th November 2017, 16:13
  2. IEC-101 serial Protocol
    By navaneet in forum zenon Energy Edition
    Last Post: 27th August 2014, 08:21
  3. Bacnet
    By poe_79 in forum Drivers
    Last Post: 31st March 2014, 15:19
  4. Fanuc Robot data exchange protocol
    By baruzlor in forum zenon Supervisor
    Last Post: 12th February 2013, 12:42
  5. Replies: 9
    Last Post: 23rd February 2012, 10:04
