Thread: Filter T_STD Event/Alarmlist
    30.03.2016
    42
    Default Filter T_STD Event/Alarmlist
    Is it possible to filter messages with the status T_STD out of the event/Alarmlist
    We see these messages comming whenever the communication to an IED is restored.
    And the timestamp is from the time that var has changed (e.g. local/remote). So that can be way back)
    Communication protocol is 61850
    18.07.2011
    138
    Default AW: Filter T_STD Event/Alarmlist
    Hi Joulzer.
    Welcome to the COPA-DATA Forum.
    In the screen switch functions for CEL and AML you can also filter for status information. To do so open the according screen switch function and go to tab "state". Here you can explicitly include or exclude states.
    You will find more information in the documentation, see screenshot attached.
    BR,
    Johannes
    30.03.2016
    42
    Default Re: Filter T_STD Event/Alarmlist
    Thanks for the fast respons. This works!!!!
    Is it also possible to filter on cause of transmissions for signals in the eventlist
    I like to filter out signals with cause of transmission 1 (COT0)
    For commands i can do this in the reactionmatrix but for signals not
    Please advice
    Thanks in advance
    18.07.2011
    138
    Hi.
    I assume you are reacting on COT via remas? So in the rema when you chose to record the COT in the chronologic event list you could also assign it an event group. You could create event groups to your needs, so you could create a group for COT events.
    The screenswitch function also allows to filter for specific event groups. So in the screen switch function you then define to only show events linked to the COT event group. This way you will only have COT events listed in your event list.
    Check out the screen shots attached to see what I mean.
    Please also consider again our documentation on how to work with alarm/event groups.
    HTH
    Johannes
    30.03.2016
    42
    Default Re: AW: Filter T_STD Event/Alarmlist
    Ok thanks for the reponse I will check it monday
  1. Lot Filter
    By jwick8801 in forum VBA
    Last Post: 27th July 2015, 16:20
  2. Alarm/event classes, areas, groups filter sort order
    By andrey_k in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 15th October 2013, 23:28
  3. CEL Filter
    By hicom in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 24th August 2010, 11:51
  4. Alarmlist text line break
    By kicker in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 28th May 2009, 08:58
