Thread: IEC104 Double Command Issue
    27.08.2015
    8
    Default IEC104 Double Command Issue
    I'm using Zenon 7.20 to communicate with SYS600 9.3 (ABB) Gateway through IEC104.
    When I do Process Command (T46): Select then Confirm ---> Close or Open Ok!
    Select then Cancel = Select then Confirm.
    Select then Exit = Select then Confirm.
    The Command Process that I'm using is a template control element.
    Could you please help me to solve this.
    Thanks & Best Regards,
    MinhKV
    845
    Default Re: IEC104 Double Command Issue
    maybe you forgot to activate property 'two-stage' in the command?
    Command Group - Action: switching command - 'two-stage'
  1. Step Position with IEC104
    By djgaunt in forum zenon Energy Edition
    Last Post: 29th January 2018, 11:57
  2. Disable double right click acknowledge
    Last Post: 29th April 2016, 07:58
  3. vba Double Command?
    By eyup in forum VBA
    Last Post: 13th August 2009, 23:59
