Thread: Numerical Value Box Maximum
    07.07.2014
    9
    Default Numerical Value Box Maximum
    I have a numerical box and it currently has a entry limit of -1000 to 1000. I have set the variable min and max to -32767 and 32767 and ticked the box to use variables settings in the numerical box but when I run the screen the mins and max still say -1000 to 1000.
    What am I doing wrong?!
    BR
    Chris
    29.01.2016
    24
    Default Re: Numerical Value Box Maximum
    Possibly under "Write set value" folder of the Entry Box properties, find the bit that says "SV limits static" and untick "Take set value limits from variable". Then you can put in limits for the text box.
    As a guide, each variable in the variable list has a limits section all of its own, so you can apply global limits for the variable and therefore not need to do it for each use of the variable, but some days you just want to do it per instance of usage and some instances of usage, like a data entry box, actually allow you to.
    07.07.2014
    9
    Hi Edgy,
    The problem was the PLC range value defaults to -1000 to 1000 even if you are bringing in an Integer or a Real ?! Changed this in the variable settings ok.
    BR
    Chris
  1. Flashing variable in numerical field
    By anemet in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 26th May 2014, 12:45
  2. Auto simulation of numerical values
    Last Post: 20th May 2014, 06:07
  3. Numerical analisys functions
    By zenmyway in forum VSTA
    Last Post: 30th August 2010, 07:08
  4. why the numerical values take its colors from rema?
    By michael_k in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 9th December 2009, 00:23
  5. Numerical Value display problem
    Last Post: 11th March 2009, 17:22
