Thread: IEC61850: error starting zenon logic application
    10.02.2015
    47
    Default IEC61850: error starting zenon logic application
    I have a problem in Zenon logic project, in specific during launch of the application.
    In the project, I configured an IEC61850 Client with many Master/port added in. Under each Master port, I created a ConnectionState variable that monitors communication among RTU (Server 61850) and driver 61850 Client.
    Project compilation doesn't return any error.
    When I try to download the application, in the Report tab in zenon logic mask minimized in icon tray, I can see following errors:
    T5BusExIec850m/QS//ConnectionState: Error adding variable
    Opening bus driver 'T5BusExIec850m' for cold resp. warm start failed
    Starting application failed
    Attached to this post you can find a screenshot about the problem.
    Thank
    Steven Costantini
    831
    Default Re: IEC61850: error starting zenon logic application
    Hard to say - on your screenshot the properties of ConnectionState variables are not visible.
    How many ConnectionState variables you have in your project? Do they have unique names?
    831
    an additional, not relevant, question - just because i'm curious about your use-case: on the screenshot i see you are using 'Win32 shared memory' driver too, what for?
    And a related question - is the problem reproducible if you create only 2 connections (so with only 2 RTUs) in driver?
    10.02.2015
    47
    I have a ConnectionState variabiable for each Master/Port device, so 19 ConnectionState variable.
    However I solved the problem!!
    Read last reply of this Thread
    10.02.2015
    47
    I solved the problem. Problem was caused by a missing license in my pc.
    Launching only Zenon Logic with Logic runtime manager, a popup advised me there was a problem with my license, instead, launching Zenon Logic after launched zenon runtime, no problems occured.
    Win32 Shared Memory permits to my project to communicate with an external software (not zenon logic application)
  1. Re: Zenon 7.10: Application error during installation
    By milad2002b in forum Editor and Runtime Setup
    Last Post: 10th June 2014, 08:51
  2. Zenon 7.10: Application error during installation
    By croc in forum Editor and Runtime Setup
    Last Post: 28th May 2014, 14:02
  3. IEC61850 Commands through Zenon Logic
    By knubla in forum Drivers
    Last Post: 16th May 2014, 12:12
  4. Replies: 0
    Last Post: 7th August 2008, 11:57
  5. error message when starting the Runtime
