Thread: Using a button inside a symbol?
    25.02.2016
    2
    Default Using a button inside a symbol?
    I'm pretty new to Zenon, but I think what I'm trying to do is relatively simple...
    I have a button inside a symbol (as well as a few indicators). I need to have a few hundred instances of this symbol on my screen.
    When pushing the button inside the symbol, it should run a function that opens a sub-screen.
    I have the button linked up to open the screen like usual, but once I instantiate the symbol on a screen, I no longer am able to click the button.
    The screen that contains the symbols will let me treat the entire symbol as a button of sorts, but that is not what I want... I want to be able to run the function that the symbol has set up.
    Is there a way to do this?
    Thanks.
    25.02.2016
    2
    Default Re: Using a button inside a symbol?
    Oh, looks like I figured out what was going on. I actually had the "Function / Variable / Function" already as a released property and did not realize it.
    All is well! Thanks.
    18.07.2011
    138
    Default AW: Using a button inside a symbol?
    Hi Evanmj.
    Welcome to our forum.
    If you are new to zenon you might be interessted in our introduction and technical videos. You will find lots of them on our homepage.
    https://www.copadata.com/de-at/news/videos/
    In addition there is also a YouTube channel which you could follow. Also check for other information sources on our homepage like KnowledgeBase, Blog, etc.
    Have fun using zenon!
    Johannes
  1. Replies: 1
    Last Post: 17th March 2015, 14:09
  2. Getting symbol name
    By dnaf in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 9th August 2013, 13:04
  3. Textbox and Send Button symbol
    By luca.bardon in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 18th October 2012, 09:21
  4. Alarm area inside another alarm area
    By davide.galigani in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 10th May 2012, 08:16
