Thread: transparent frame
    09.05.2012
    4
    Default transparent frame
    Is it possible to have a transparent frame ?
    The goal is to define a customized shape with a shadow visible over the background screen for a menu window (not modal popup).
    Thx for any support,
    24.07.2008
    88
    Default AW: transparent frame
    Hi there,
    check out "Freely defeineable frame shapes".
    Select your frame and at properties activate "Freely defineable frame shape" and then define free frame shape.
    Then you can add a rectangle which covers most of the screen and set it to "Cover".
    Add another element and set it to "Cut" in order to make a "hole" into the frame.
    You can see the result in the attached screenshot.
    Konstantin
    09.05.2012
    4
    Default Re: transparent frame
    Thx for your reply.
    The freely defined shape is actually ok. What I try to obtain is a shadow effect of the popup freely defined screen (which is not modal) over the background screen.
    Check the attached file, there is an example of what I would like to create. Hope it's clearer
    Thx
    24.07.2008
    88
    Hey,
    thanks for the picture, now it's clear what you want.
    Unfortunately it's not possible to draw outside of the free frame.
    You can only fake it - but then there would be no real half transparency.
    Konstantin
  1. Zenon WPF element background transparent
    By markusegle in forum VSTA
    Last Post: 5th February 2018, 09:29
  2. Activate Frame
    By dario in forum VBA
    Last Post: 26th April 2013, 09:29
  3. Transparent Clock element?
    By mvj in forum zenon Supervisor
    Last Post: 2nd March 2010, 14:08
