Thread: Modbus Process Gateway
    12.02.2016
    4
    Default Modbus Process Gateway
    Hey,
    With two servers (HP Server used for data acquisition) and zenon running in Software Redundancy mode with three Runtime clients only, I want to configure Modbus process gateway for data transmission to DCS over Modbus over TCP/IP protocal on redundant link.
    How will Zenon gateway act over redundant link? Will Zenon gateway act parallel in for DCS making data available over both links simultaneously or on failure of main Server, the same shall switchover.
    My requirement is of switchover in case of failure of either Servers. Can I configure the gateway to meet the requirement?
    904
    Default Re: Modbus Process Gateway
    You may start zenon Process Gateway on many computers in zenon Network, e.g. on network Server 1 (process Server) and Server 2 (standby). The process data is the same on all computers in zenon Network - so each Gateway will deliver the same mirror to DCS. Configure the Gateways to use different IP and/or Slave ID (demanding what DCS is expecting for redundancy).
    And when DCS writes to a zenon PG - it transfer it to zenon Runtime as event. So it will be enough if one Gateway will receive a write request. When both zenPG receive the same request - will be still OK - both will transfer the same event to RT. Already the first event will update the process.
  1. Modbus Process Gateway
    By hussaini in forum Drivers
    Last Post: 12th November 2015, 14:08
  2. Process gateway Modbus
    By archie in forum Drivers
    Last Post: 13th November 2014, 07:21
  3. Modbus Process Gateway
    By navaneet in forum Drivers
    Last Post: 19th June 2014, 07:47
  4. Process gateway(Modbus)
    By ansab.tp in forum Drivers
    Last Post: 12th February 2013, 12:33
  5. Process Gateway
    By murphys in forum Drivers
