Thread: Using Variables form Zenon in C#
    29.01.2016
    19
    Frage Using Variables form Zenon in C#
    Hello.
    How can I read and write to the Zenon variables?
    I tryied it following way:
    zenOn.IVariable Registr;
    Registr.set_Value(0, valueInC#)
    Error: Use of unassigned local variable Registr
    Thank you
    08.08.2013
    44
    Default Re: Using Variables form Zenon in C#
    Hi DavidMarek,
    you did not define you local variable, so therefore you tried to access a null reference which is not possible.
    A proper way can look like this:
            public void Macro_GetSetValue()
                zenOn.IVariable myVar = this.Variables().Item("myzenonVariable");
                //check if the variable is advised to read the value
                if (myVar.IsOnline() == true)
                    myVar.get_Value(0);
                //set a value to the variable
                myVar.set_Value(0, 10);
    Further Information can be found in the zenon help under the following chapter:
    Manual -> Programming interfaces -> Objectmodel -> Variable
    BR
    Christian
  1. zenon logic doesn't communicate with external variables in zenon
  2. Re: zenon logic doesn't communicate with external variables in zenon
  3. Replies: 1
    Last Post: 31st January 2011, 15:23
  4. Replies: 1
    Last Post: 3rd August 2010, 10:02
  5. Replies: 0
    Last Post: 12th May 2010, 09:58
