Thread: Function scripts can not delete
    Default Function scripts can not delete
    Hi
    I got some function scripts can not be delete.
    After that It seem cause new function can not work.
    My zenon is 6.50
    Could you please help?
    Brgds
    831
    Default Re: Function scripts can not delete
    I'm suspecting that your project in Editor may be partially corrupted. You may try to save from this project as much as possible doing following:
    1. create project backup
    2. restore this backup as new project (is a checkbox in restore dialog)
    The version 6.50 is already few years old an not actively supported. I'm recommending you to update - at least Editor - to newest one - 7.20 or soon - 7.50. If you don't want to update zenon installations on Runtime PCs, then you can design/update project in newest Editor and then compile the project to the older version.
    Hi
    I backup project (6.50 ) and restore as new project (7.20 demo).
    I deleted the function script that it did not work , and I do not need it
    After that I create runtime for 6.50 but I got some error warning.
    Could you give me your idea about it
    Brgds
    Sky
    Attached Files Attached Files
    18.07.2011
    136
    Default AW: Function scripts can not delete
    Hi Skywalker.
    The error message shown indicates an editor crash. This has to be analyzed by the official support.
    Would you please forward that information to your local zenon support, they will take care of that request.
    Please attach the rar file and in addition please also send them the project backup which you created in 6.50.
    BR,
    Johannes
  1. Delete structured tag
    By fabios in forum VBA
    Last Post: 28th July 2008, 14:39
  2. Delete item in a combobox
    Last Post: 11th July 2008, 10:43
  3. Renaming scripts loses the link at the function
    Last Post: 3rd August 2007, 07:23
