Thread: Data acquisition from 3 different PLC
    02.02.2016
    Frage Data acquisition from 3 different PLC
    I'm not aware that how to collect the data from 3 different PLC, main problem is that how to separate these data in separate reports(separate batch reports). Also it is same for event and alarm report.
    I'm using zenon 7.20
    09.03.2011
    44
    Default Re: Data acquisition from 3 different PLC
    Dear surajbhosale09,
    The first step will be to stablish communication with the different PLCs, and define the variables you want to collect from each of them.
    Then, you can create reports/filters for this specific data. You have different ways of filtering, you can even create alarm groups, areas, ...
    You can find more information on the help, on the topics Drivers, Report, AML or CEL.
    I recommend you to contact your local support for further information.
    Steffi
  1. Replies: 0
    Last Post: 1st May 2015, 18:10
  2. Read I/O from BECKHOFF PLC
    By satyngar in forum Drivers
    Last Post: 16th June 2014, 15:44
  3. Setting for Restoring PLC Value.
    By navaneet in forum zenon Supervisor
    Last Post: 9th September 2013, 00:09
  4. PLC redundancy
    By gyu in forum Drivers
    Last Post: 17th May 2011, 05:29
  5. how to simulate PLC data?
    By gralex in forum Drivers
    Last Post: 18th March 2009, 09:50
