Thread: Settings for the aml don't take any effect
    Default Settings for the aml don't take any effect
    I need to make same changes at the layout of the AML, but when i set the settings in the editor and then copy it to the runtime, it doesn't take any effect. In the project.ini it is set, but the runtime always show the standart layout.
    greetings
    matthias
    Default Re: Settings for the aml don't take any effect
    there are two places where the layout (number of columns, width of columns etc) can be configured.
    One central layout can be defined, which is valid for all newly created picture switch functions. (in zenon 5.50, only this layout existed, valid for all AML pictures)
    Also at the picture switch function itself, the layout (number of columns, width etc) can be defined. This allows for different AML pictures to be shown.
    Note that changing the central layout, does not affect the existing picture switch functions to the alarm picture. These will have to be modified additionally.
    Thank you very much it works now.
    Great!
