Thread: How to define register address dynamically?
    12.12.2014
    7
    Default How to define register address dynamically?
    Hello everyone,
    I have to read event buffer from one device. It would be hell of a work to define all of the registers from buffer - so I wanted to define only 5 variables, all of the rest is the same. I mean, I have 500 registers - every event has one for event code and 4 for date and time.
    So my question is: am I able to dynamically write register address? It would be really helpful
    1,059
    Default Re: How to define register address dynamically?
    Maybe would be helpful but unfortunately also a "nice feature" to omit the license
    In Logic you can easy create many variables - use 'Add multi variables' - available by right-click in variable list.
    When these are variables for a driver with profile you can from Profile dialog export (available by right click there) single variable(s) to a text file (*.CSV), then using any editor, e.g. Notepad, Word etc., you can add entries in file and then import into Profile list back.
    12.12.2014
    7
    I do not have to omit the license - I have unlimited tags in Logic
    But creating thousands of variables is not "efficient engineering", "ergonomic & dynamic process solutions" and most of all - it is not "do it your way"
    Most systems allow you to use pointers or something like that and I hoped for same solution in Logic...
  1. Event Register - export options
    By yolovs in forum zenon Energy Edition
    Last Post: 17th May 2013, 08:33
  2. dynamically create Alarm Areas
    By mkerle in forum VSTA
    Last Post: 24th November 2011, 09:47
  3. How can I read this two type of Data register?
    By michael_k in forum Drivers
    Last Post: 24th November 2009, 16:23
  4. Dynamically changing alarm descriptions
    By mattsd in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 9th November 2007, 10:44
