Thread: Get Cureent Event Logged in CEL
    27.07.2015
    9
    Default Get Cureent Event Logged in CEL
    I want to get the current event logged in CEL in message box.Message box should describe Timestamp,Text,Variable name,Logged in User.
    Please help how to get the Current CEL event.
    Default Re: Get Cureent Event Logged in CEL
    Hi jwick8801,
    It is not a good idea to display message boxes during runtime, as these can be blocking and would affect your runtime system.
    What would be possible, is to fetch CEL events and write the value to an internal variable in the runtime.
    As this can cause a big load on the system if many CEL events are created or even an "endless loop" if writing variable values via the API is logged in the event list, you should consider carefully how you are going to do this.
    Can you tell a bit more about what exactly you want to achieve?
  1. Alarm and Event
    Last Post: 14th November 2014, 13:13
  2. Event list
    By xeren in forum Drivers
    Last Post: 24th October 2013, 07:18
  3. display administrator logged in
    Last Post: 15th May 2012, 04:35
  4. Log changes into cronologic event list (CEL)
    Last Post: 8th April 2009, 07:22
  5. Access New CEL item event from VBA
    By karimsaikali in forum VBA
    Last Post: 12th March 2009, 08:56
