Thread: Extended curves - Frame Specific Functions
    bastien Gast
    Default Extended curves - Frame Specific Functions
    Good afternoon.
    I'm working on Zenon 7.20 and I wanted to apply graphic files to extended curves's frame specific buttons, to make them more "user-friendly".
    The problem is, if you press the "start" button for example, and the trends are displayed, the play button is then grey (as if locked).
    I don't want to show text on my buttons because I want them to be quiet small.
    I'd like to find a way to make my graphic files either grey or invisible.
    For example, the graphic file assigned to the play button should be grey / locked, when the trends are playing.
    Has someone any idea ?
    Thanks for your replies.
    14.08.2015
    6
    Default Re: Extended curves - Frame Specific Functions
    You can do this with different way:
    For example two options:
    You Change the Fill Color different fill color of the element
    And if is function lock color are Grey.
    Or with intern variable you can visibility the Button.
    BR
    Daniel
  1. How can I print a not displayed frame?
    By mjackson in forum zenon Supervisor
    Last Post: 21st November 2014, 15:13
  2. Size Frame (Screen) during runime
    By sabbonis in forum VBA
    Last Post: 29th January 2014, 15:21
  3. Activate Frame
    By dario in forum VBA
    Last Post: 26th April 2013, 09:29
  4. Open Web page in Frame
    By focus in forum zenon Supervisor
    Last Post: 20th February 2012, 10:23
