Showing results 1 to 1 of 1
Thread: zenon 7.20 SP0 - Installation Wizard; Warning: 1946
    11.06.2013
    32
    Default zenon 7.20 SP0 - Installation Wizard; Warning: 1946
    Hi zenon community!
    There could be an issue during installation.
    we have also seen this behavior on Windows 7 – but as Microsoft mentioned: This behavior is by design. You can safely ignore this warning message.
    Microsoft-Support
    This behavior sometimes appears on a not fully patched maschine if zenon was already installed – installing the zenon 7.20 LP and not all shortcuts were removed from the system.
    This attribute marks the shortcut as a “NoPin” Shortcut – which needs to be set for Windows 8 and older – otherwise all shortcuts are placed on the start screen.
    Br
  1. Zenon 7.00 SP0 build4
    By xeren in forum Editor and Runtime Setup
    Last Post: 6th June 2017, 08:00
  2. Replies: 0
    Last Post: 30th July 2015, 15:02
  3. Zenon runtime security warning
    By jurijcadez in forum zenon Supervisor
    Last Post: 4th June 2013, 01:29
  4. Zenon 6.50 Sp0 build 1 warning
    By skywalker in forum zenon Energy Edition
    Last Post: 11th August 2010, 08:19
  5. installation of 6.22 SP0 hangs, leaving the system in an inoperable state
    By markclemens in forum Editor and Runtime Setup
    Last Post: 10th March 2008, 17:44
