Thread: Upgrade from zenon 6.50 tto zenon 7.2
    Default Upgrade from zenon 6.50 tto zenon 7.2
    Hi
    We want to upgrade our system / database from 6.50 to 7.20.
    We will upgrade OS system from window server 2003 to 2008 64bit for extension memory, SQL from 2005 to 2012.
    But we still concert that zenon database upgrade from 6.50 to 7.20. Do we need to upgrade to 7.0 and to 7.20 later and do it has any restrict?
    Thanks and regards
    louis.paglaiccetti Gast
    Default Re: Upgrade from zenon 6.50 to zenon 7.2
    You can convert the project directly from 6.51 to 7.20, without any intermediate steps. The typical process is to simply restore either a project or workspace backup into the editor of the newer version.
    However, there are 2 places you will want to checkout prior to your upgrade.
    First, have a look at zenon 7.20 documentation, there is a chapter called “Project conversion”. This outlines important information and things to be aware of between the versions. There is another document available with each release called “release notes”, this highlights important product changes, features, and enhancements which you may also want look over.
    As a wise practice, I recommend you to also to some amount of testing with your project in the new version.
  1. Replies: 5
    Last Post: 30th July 2018, 10:45
  2. zenon logic doesn't communicate with external variables in zenon
    By mashjj in forum straton / zenon Logic
    Last Post: 27th February 2015, 13:10
  3. Re: zenon logic doesn't communicate with external variables in zenon
    By anjali.gk.nair@gmail.com in forum straton / zenon Logic
    Last Post: 22nd August 2014, 10:51
  4. Replies: 2
    Last Post: 14th February 2013, 15:25
