Thread: WebClient "controll cannot be started"
    27.08.2008
    50
    Default WebClient "controll cannot be started"
    Hello!
    I am running into some problems at a customer project.
    It seems that the ZenOn services are blocked on some PCs (other PCs in the same network work properly).
    The user used on the PCs got granted admin rights but we still get the attached messages when opening the ZenOn WebClient.
    OS: Windows 7 64bit
    ZenOn Version: ZenOn 7.11 SP0
    Any idea what could block ZenOn WebClient or how to unblock the ZenOn Services on Windows 7?
    Thanks!
    Greetings
    Thomas
    Default AW: WebClient "controll cannot be started"
    can you try to run the Internet Explorer as Administrator and see if that works?
    (If it works, the information may be help for further investigation).
    08.10.2007
    35
    Default Re: WebClient "controll cannot be started"
    Just FYI, this post express the most ports used by zenon!
    http://www.copadata.com/forums/showthread.php?t=156
    Hi Thomas,
    It is possible that during installation of the webclient, a third party anti-virus software with built-in firewall blocked access to the zenAdminSrv.
    Another possibility could be that the zenAdminSrv is not running.
    Another possibility is that the port that is used by default by the zenAdminSrv, is used by a different process. In 7.20 it is possible to configure the ports used by services through the startup tool. Here you can also assign a network card.
    For the zenAdminSrv it is recommended to assign the local loopback adapter.
    27.08.2008
    50
    Hello!
    Thank you for all your fast answers.
    We just had to start the IE in Administrator mode and it worked.
    Greetings
    Thomas
  2. Note: 7.10 DVD Webclient "big setup" and zenadminsrv/zenlogsrv problem
    By christian.hayna in forum Editor and Runtime Setup
    Last Post: 8th October 2013, 16:29
  3. Alarmmeldeliste Filter "nicht quittiert" ODER "anstehend"
    Last Post: 31st July 2012, 15:20
  4. Replies: 5
