Thread: Import Variables
    dak2483 Gast
    Default Import Variables
    I am unable to import variables from RSLogix 5000. I am using zenOn eidtor 6.22 which just allows me to import S7 variables and .XML files.
    Default Re: Import Variables
    please try the following:
    in the project tree, click on driver below the variables node, and select the RSlogix driver. Then right-click on the driver, and choose "import variables online" from the context menu. A dialog should appear, and a connection to the PLC will be established for online browsing of the variables.
    dak2483 Gast
    hey Mark,
    Thanks for the quick reply. Yes it worked. I did try that before but just did not do it online that is why it would not show me all the variables,
    Thanks again.
  1. PLC Variables and Internal Variables
    By madphilly in forum Drivers
  2. Help! I can not import my variables .dbf file
  3. Replies: 0
