Thread: Sicam 7.00 Build3 Runtime unexpectedly going to shutdown
    27.12.2013
    Default Sicam 7.00 Build3 Runtime unexpectedly going to shutdown
    Runtime is going to freeze after 20-30 min. later it's going to shutdown without giving any error when I simulate single point or double point signals from RTU or Field.
    Before going to shutdown, i can see all changes in this signals at AK Driver.
    If there is no change in single or double point signals, Its working perfectly for measurements (analog) values.
    Also, Stanby server could not take over when main server crushes like this.
    Any help would be greatly appreciated.
    Best Regards
    Halil
    870
    Default Re: Sicam 7.00 Build3 Runtime unexpectedly going to shutdown
    For me looks for a case for SICAM Support, not for Forum by COPA-DATA.
    Have you took look on Task Manager - CPU Load (per each processor)? Does the "freeze" mean that the RT does not react on try to open another screen etc?
    Then the RT is probably too busy or blocked or the function queue grows faster as processing these functions. VBA?
    Maybe you have some limit functions linked to spi/dpi and these functions are causing calls of another functions or resources-expensive things? Recursive calls of function/screens may cause similar effects.
    Maybe is there something in LOG?
  1. Sicam 230
    By yolovs in forum zenon Energy Edition
    Last Post: 13th June 2016, 08:46
  2. Sicam 230
    By tihomir in forum zenon Energy Edition
    Last Post: 27th May 2014, 06:55
  3. interrupted unexpectedly in zenOn6.51
    By zhangbb_dimension in forum zenon Supervisor
    Last Post: 28th May 2012, 23:30
  4. help in Sicam 230
    By imran in forum zenon Energy Edition
    Last Post: 11th May 2012, 00:11
  5. Operating System Shutdown throw Zenon
    By yara in forum zenon Supervisor
    Last Post: 30th January 2012, 23:15
