Thread: delay in redundancy
    10.11.2014
    24
    Default delay in redundancy
    Hello ,
    Ií m glad to tell you that redundancy had finally worked, but I have some problems with delays response, because when I disconnect the primary server, I must wait more than 30 seconds to visualize my states. In other hand, when I disconnect the secondary server I donít have such a delay.
    One other thing is that I have the entire view of my application just in server1, for the 2 others (server2 and PC-client) I canít visualize my tab menu.
    Enclosed, you can see pictures that show what i previously described.
    louis.paglaiccetti Gast
    Default Re: delay in redundancy
    I assume the 30 seconds you see is simply a network timeout setting, The standby server maintains a buffer to take care of data and ensure there is no data loss between the time the failure actually occurs, and the time the standby recognizes the failure.
    In the zenon Startup Tool -> Application -> Options -> Network configuration, there is a setting where you can define the Network communication timeout. This setting is PC Specific, so do not forget to apply it to other clients if so desired.
    Find more information in the zenon Help:
    Manual -> Tools -> Startup Tool -> Start dialog -> Application -> Network configuration
    10.11.2014
    24
    dear louis.paglaiccetti
    how to view the tab menu in both servers 1 and 2, and the PC-client
    Best regards
    Maybe you have an AUTOSTART script in zenon (under Functions->Scripts) which loads your menus? Well in a zenon network project, you will want to copy/paste that autostart script and give them special names to also be executed on the clients:
    AUSTOSTART_CLIENT
    ...somefunction
    ...somefunction
    Check the zenon tutorial for a practical example: Manual (F1) -> First steps -> Scripts -> Creating scripts
    Check the zenon documentation for further explanation: Manual (F1) -> Functions and scripts -> Scripts -> Pre-defined scripts
    Also, with network project, you must also be aware about internal variables and their "Calculation" property. Check out Manual (F1) - > Drivers -> Internal -> Driver-specific functions.
  1. Time Delay in Script execution
    Last Post: 19th July 2017, 10:04
  2. Dynamic Alarm delay
    By crl_snef in forum zenon Supervisor
    Last Post: 29th January 2015, 09:16
  3. Variables with delay and red square
    By luizmartinsbr in forum zenon Supervisor
    Last Post: 9th October 2013, 23:07
  4. Alarm delay using Limits not working correctly
    By joulz in forum zenon Energy Edition
    Last Post: 10th March 2011, 15:40
  5. Edit Variable limit (Delay)
    By rloureiro in forum VBA
    Last Post: 12th September 2008, 09:25
