Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 11
Thread: redundancy problem in server
    10.11.2014
    24
    Lächeln redundancy problem in server
    hello everyone I have this architecture
    + 2 servers SEL3354
    * server 1:
    -name pc: SEL3354-1
    -network card 1: 192.168.1.20 / 255.255.255.0
    -network card 1: 192.168.1.21 / 255.255.255.0
    * Server 2:
    -name pc: SEL3354-2
    -network card 1: 192.168.1.22 / 255.255.255.0
    -network card 1: 192.168.1.23 / 255.255.255.0
    + HMI Panel PC
    -name pc: PC-HMI
    -network card 1: 192.168.1.100 / 255.255.255.0
    How to send runtime files
    to HMI, server 1, server 2
    is that like this??????
    [ATTACH][ATTACH]Click image for larger version
    please check this setting. and tell me is that it is correct or not
    thank you.
    10.11.2014
    24
    Lächeln Re: redundancy problem in server
    I forgive errors in writing :
    -network card 1
    -network card 2
    for PC-HMI the IP address is 192.168.1.100 and 192.168.1.200
    not 192.168.1.100 and 192.168.1.100
    Default Re: redundancy problem in server
    Hello hajjsaid99,
    In the project properties, please use the computer name of server 1 and server 2 instead of the IP address. zenon networking requires the computer name to be used and network name resolution to be available in the network. Name resolution can be achieved through a DNS server or local "HOSTS" files.
    Your remote transport settings basically are correct. You can do a remote transport like this, first for server 1, then for the server 2 and finally for the HMI client.
    Once the runtime files are transported for the first time, and the runtime is running, you only need to transport the runtime files to current server and perform a reload of the runtime. The standby server and the HMI client will then be automatically updated.
    Instead of the remote transport, you can also use the topology view in the zenon editor. Here you can create entries for your server 1, server 2 and the HMI client, set the start project and define the location where the runtime files should be located. After the configuration is done, you can then transfer the runtime files to all configured systems.
    10.11.2014
    24
    dear markclemens
    I made this change but it does not work
    for seveur just install zenon runtime or it asks other configuration.
    Hi hajjsaid99,
    Unfortunately, I'm not quite sure what exactly does not work.
    You do need to install the zenon runtime on all three PCs prior to attempting a remote transport.
    10.11.2014
    24
    okay
    for this I have a question
    we declare the server name in project properties - Network
    but not declare the client PC.
    -so the client PC, how to communicate with the servers ?????
    -is that does not require a specific configuration, ??????
    thank you and sorry for the bad english
    You use remote transport to transport the runtime files to the client. In the runtime files it is specified which computer is server 1 and which computer is server 2.
    So when the runtime on the client starts, it already has the local runtime files. From these files it knows that it needs to connect to its primary server or secondary server.
    10.11.2014
    24
    dear markclemens
    ok merci beaucoup
    10.11.2014
    24
    Hello Mr markclemens,
    First, thank you for your valuable help.
    I’ m glad to tell you that redundancy had finally worked, but I have some problems with delays response, because when I disconnect the primary server, I must wait more than 30 seconds to visualize my states. In other hand, when I disconnect the secondary server I don’t have such a delay.
    One other thing is that I have the entire view of my application just in server1, for the 2 others (server2 and PC-client) I can’t visualize my tab menu.
    Enclosed, you can see pictures that show what i previously described.
ID:	1725,Click image for larger version
ID:	1726,Click image for larger version
    Thanks a lot for your feedback
    10.12.2007
    272
    Default AW: redundancy problem in server
    I think there is a AUTOSTART_CLIENT Script missing. The Server 1 runs the AUTOSTART/AUTOSTART_SERVER Script but the Clients (the Standby Server is also a Client when Server1 is running) only Show the startpicture.
    Goto Functions -> scripts and create AUTOSTART_CLIENt Script and link the same functions (or what you want to be executed on the Clients) as in the AUTOSTART/SERVER Script.
  1. Server redundancy
    By tauhien in forum zenon Network
    Last Post: 27th May 2011, 00:21
  2. Problem with server redundants
    By mohamad.kasaeifard in forum zenon Network
    Last Post: 23rd May 2011, 00:16
  3. Client / Server problem
    By stevegrice in forum zenon Network
    Last Post: 9th December 2009, 01:58
  4. Archive Server Problem
    By rloureiro in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 28th August 2008, 14:56
  5. Replies: 0
    Last Post: 21st August 2007, 09:35
