sorry for late answer - i have overlooked the post...
In the Runtime, the right-click on screen element per default displays context info about variable linked with the element. It does it when element representation property 'Display status of variable' is active.
On screenshot i see that this property is active - as only then there could be also a "red square" in right-upper element corner. The red point on element is indicator that variable has one (or more) of following status bits:
INVALID - bit 18
OFF - bit 20
ALT_VAL - bit 27
REVISION - bit 9
TIMEOUT - bit 11
FM_TR - bit 24
the names of current status bits are displayed in context info of element (right-click) in the Runtime.
The bit 29 (you are using in Logic) is N_UPDATE and on elements would be displayed as "blue square" graphic, not red. It means that responsible project server/standby is not delivering values for affected variable.
Is this a zenon variable set to be 'extern visible'? What a driver in zenon?
The Logic function VSIGETBIT will result 'TRUE' only if also in zenon this bit by variable is set (and only if you configured Logic correctly).
I propose you to first link in zenon 2 variables with screen elements - one variable which you are sure it is updated, second - not updated, both from this driver. And then in the Runtime - when you right-click on the screen element - a context tooltip will open with information also about status bits of linked variable.
If in zenon - in the context info on screen element - you see the status bit, but not in Logic via VSI* function - then your Logic is not configured correctly.
Der Treiber ist: S7TCP32 und "extern visible" ist angewählt.
Im Anhang sind zwei Screenshots: 1. Runtime Status, 2. Logic
Da ich das Projekt nur auf meinem Rechner ausführe und keine Verbiindung zur S7 habe, wird es in Runtime erkannt.
Die Logic Verknüpfung erkennt es nur beim Spont und VSIGETBIT( E7_2, 18 ).
Ich versuche dadurch den Ausfall der DP-Teilnehmer zu erkennen.
Ich bitte um Entschuldigung aber ich habe leider nicht gefunden, wo ich den Rechtsklick für Tooltip (Status- Anzeige) konfigurieren kann.
INVALID - bit 18
OFF - bit 20
ALT_VAL - bit 27
REVISION - bit 9
TIMEOUT - bit 11
FM_TR - bit 24
