Thread: Changing Variable Name in Zenon Logic
    16.06.2015
    5
    Ausrufezeichen Changing Variable Name in Zenon Logic
    I am using Zenon Variables in Zenon Logic. I wrote some Programs using those Variables by dragging and dropping them and every thing is working. The only problem is when a Variable name changes in Zenon it also changes in the Variable declaration in Zenon Logic but it does not change automatically in the Programs. I have to do that manually by going throw all the programs. Is There any way to make that happen Automatically?
    Thanks in advance.
    20.08.2009
    293
    Default AW: Changing Variable Name in Zenon Logic
    no, there is no built-in way to do this.
    Depending on your source code in zenon Logic (e.g. if the code is in ST) you could do some kind of search & replace to save some time.
    Kind regards,
    Bernhard
    16.06.2015
    5
    Default Re: Changing Variable Name in Zenon Logic
    Ok. This is bad!!
    Thanks any way.
  1. zenon logic
    By nikabena in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 26th March 2015, 21:44
  2. zenon logic doesn't communicate with external variables in zenon
    By mashjj in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 27th February 2015, 13:10
  3. Re: zenon logic doesn't communicate with external variables in zenon
    By anjali.gk.nair@gmail.com in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 22nd August 2014, 10:51
  4. Zenon logic
    By sidramsatyal in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 1st July 2014, 09:45
  5. Response variable changing disables Action Buttons
    By stolyarov_as in forum zenon Energy Edition
    Last Post: 12th July 2013, 09:47
