Thread: Recieving Goose on Raspberry Pi (Straton)
    03.11.2014
    10
    Default Recieving Goose on Raspberry Pi (Straton)
    I am trying to configure my straton running on Raspberry Pi to recieve goose. however, I get the following error (see attached file).
    However, i dont know why it says "MMS", since I am using Goose.
    Anyone got a clue?
    Best,
    Jonas
    816
    Default Re: Recieving Goose on Raspberry Pi (Straton)
    I'm not specialist for straton on linux but i suppose it writes "MMS" as such reference could be eventually used in MMS, but not in GOOSE subscription as this is probably not configured correctly.
    1. right click on IEC61850 Server driver - 'read variables from SCL'
    2. on first tab import own SCL file (e.g. subscriber.icd). You do not need to create any variables (checkboxes in tree) but you have to import file anyway as else the 850-server will not start.A valid server must have at least some mandatory items in its own SCL, even when then uses only GOOSE subscription (receives GOOSE but does not communicate via MMS with any 850-client).
    3. on second tab - 'GOOSE' import SCL file of the GOOSE publisher (850-server sending GOOSE). It is NOT the same SCL-file!
    4.In tree for GOOSE pick up (set checkbox) by data attribute (end-items, without sub-nodes) you know the publisher will send some value changes --> Workbench will create a variable you then can use in program code or view when you connect WB online with Runtime on Raspberry.
    03.11.2014
    10
    Thank you for your help.
    However, when it is recieving goose from the SCADA now it crashes and another line is added to the command (see attached picture).
    Does anyone managed to get rasp pi to recieve goose messages?
    Best,
    Jonas
    03.11.2014
    10
    picture of whats happening attached...
  1. What is STRATON anyway?
    By markclemens in forum straton / zenon Logic
    Last Post: 7th July 2016, 07:23
  2. Re: AW: Using Straton with Zenon
    By yara in forum straton / zenon Logic
    Last Post: 4th October 2013, 07:45
  3. STRATON error
    By ansab.tp in forum straton / zenon Logic
    Last Post: 17th September 2012, 05:41
  4. GOOSE messages in STRATON
    By mansoorhussain in forum straton / zenon Logic
    Last Post: 14th January 2011, 00:37
