Thread: Use of Zénon Operator ?
    16.07.2013
    2
    Default Use of Zénon Operator ?
    I want to develop a module based on Zénon but i wonder i should use Supervisor or Operator. In fact, this module should communicate through Modbus TCP with 2 other Modbus servers and shall implement himself a Modbus Server. Can i use Zénon Operator for that ?
    Thanks !
    20.07.2012
    6
    Default AW: Use of Zénon Operator ?
    Hi florian,
    zenon already offers a functionality of zenon Modbus Slave (Server) - "Process Gateway", please consider following chapter of the documentation (help):
    Manual -> Process Gateway -> MODBUS Slave
    so there is not need, to implement it by yourself.
    In such situation, you should usually consider following manual (help) chapter:
    Manual -> zenon Operator -> Restrictions for the zenon Operator
    Unfortunately, Process Gateway functionality is not available for zenon Operator license.
    Nevertheless, I would suggest you to contact with your local sales representative - who can help you to choose appropriate license.
    Regards
    Piotr
  1. error in installing zenon7 operator about the sql
    Last Post: 29th May 2012, 03:02
