Thread: Rgm
    22.10.2013
    14
    Default Rgm
    Hello.
    I want to do the next but I do not find the good way to do it:
    1- I have a RGM with a lot of variables.
    2- I create a screen with screentype recipegroup manager and I create several buttons.
    3- When I press button READ ALL VALUES -- I read all the values which are in my RGM.
    Until here, no problem. My problem comes when I want to write.
    I do not want to write all values from my RGM and I do not want to select variable per variable.
    What I really want is:
    1- Define several group of variables.
    GROUP 1 - variable 1 and variable 2
    GROUP 2 - variable 3 and variable 4
    GROUP 3 - variable 5 and variable 6
    GROUP 4 - variable 7 and variable 8
    2- Select (in RT) the recipe from RGM that I want (it is possible I have several possibilities)
    3-Later, with 4 checkbox, select which groups I want to write.
    4- Write the variables.
    How can I do it??? I was trying to do it through VBA but I cannot achieve any good result.
    Can you help me??
    R,
    22.10.2013
    14
    Default Re: Rgm
    Some answer????
    25.06.2012
    156
    Default Re: Rgm
    Hello rgv0021,
    you can split the variable grouping in different recipes in the same recipe group, so that only some of the variables (group) are read/written from/to the process level. Additionally, you can define a "group ALL" with all the variables to be read/write at the same time from/to the process level.
    Then, in the runtime it is only needed to select which recipe (group of variables) it is to be write/read to/from the PLC.
    Find attached some pictures showing a possible solution to implement this functionality (editor + runtime).
    As you can see depending on the group of variables it is defined different actions to the variables in the group/recipe ("Modify spontaneous value" or "No action") so that those are possible to write/read or not.
    Please let us know if this solution helped you sort out this problem.
    I wish you the best luck.
    David Cerdeira
  1. RGM actual recipe
    By scadavmesnik in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 8th July 2012, 23:56
  2. RGM info
    By gozzi in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 2nd March 2011, 23:25
  3. RGM-Datensicherung
    By axel_sch in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 16th December 2008, 11:16
