Thread: automatic switching (substation automation)
    14.04.2015
    2
    Default automatic switching (substation automation)
    Dear support
    I'm working with system of substation automation.
    This system controls and manages switchgear.
    I'm looking for solution to make automatic switching. I mean sequence of switching command (switchgears and circuit breaker) with control of position change. For example to switch from one bus to another.
    18.07.2011
    138
    Default AW: automatic switching (substation automation)
    hi elsoportar.
    A warm welcome to the COPA-DATA Forum.
    What you are looking for is what we call a command sequence. With version 7.20 COPA-DATA introduced a new module to create, administrate and process such command sequences.
    Are you running zenon Version 7.20 or a lower Version?
    Johannes
    14.04.2015
    2
    Default Re: automatic switching (substation automation)
    Johannes, thanks for your answer.
    As for right now, I'm using Zenon 7.11. But I'm ready for 7.20 (have proper licence).
    Concerning this module, is it requires separate licence And where can I get manual for this module?
    18.07.2011
    138
    Hi.
    Yes, the modul must be licensed. Please contact your sales representative if you would like to upgrade your license with that module.
    A precise described of that module is part of the zenon help, you find it under Manual - command sequencer.
    If you are customer already and registered yourself on our homepage you may download the documentation for version 7.20. Please check out the downloadsection to do so.
    best regards,
    Johannes
  1. Automatic Backup
    Last Post: 30th July 2019, 01:57
  2. Automatic Line Coloring
    Last Post: 12th July 2013, 13:50
  3. Switching variables in Report
    By a.oprean in forum zenon Supervisor
    Last Post: 15th January 2013, 02:05
  4. Automatic Keyboard Display
    By bastien in forum zenon Supervisor
    Last Post: 15th January 2013, 01:49
  5. Automatic Logout
    Last Post: 27th August 2009, 00:08
