Thread: SystemModelGroup for variable
    Default SystemModelGroup for variable
    Hi All
    I'm using zenon v 7.11.
    Is it possible to get a property of variable "SystemModelGroup" in Runtime with VSTA?
    This property is existing in DynProperties of variable but I can't get its value or text.
    Dmitry
    Default AW: SystemModelGroup for variable
    what you should get from the DynProperty SystemModelGroup is a string of semicolon separated Guids.
    These Guids you can also find in the Equipment Model structure of the project.
    See attached *.txt file (rename it to *.cs or copy the content)/helper classes which parses the equipment model structure of the project and returns a dictionary of Guids and the readable values.
    EquipmentModelHelper.txt
    The only thing left you need to do is then to resolve the Guid from your variable with the Guid from the dictionary, with a function like below:
    private String GetEquipmentGroupStringByGuids(String pEquipmentGroupGuids)
          if (String.IsNullOrEmpty(pEquipmentGroupGuids))
            return String.Empty;
          //Separate the Guids, store in array
          String[] equipmentGroupGuidArray = pEquipmentGroupGuids.Split(';');
          String equipmentGroupString = String.Empty;
          //Iterate through the array
          int index = 0;
          foreach (string guid in equipmentGroupGuidArray)
            //Get the equipment group string for the given guid
            String currentEquipmentGroupString;
            equipmentGroups.TryGetValue(new Guid(guid), out currentEquipmentGroupString);
            //If the equipment group can be found (not deleted in zenon)
            if (currentEquipmentGroupString != null)
              //Add ";" before each substring (exclude first one)
              if (index > 0)
                equipmentGroupString += ";";
              equipmentGroupString += currentEquipmentGroupString;
              index++;
          return equipmentGroupString;
    Default Re: SystemModelGroup for variable
    Bernhard,
    Thank you for this example.
    I am in ecstasy of this code
    I will try it.
    Why is it so difficulty? I only want to get a string
    Dmitry
    Daumen hoch Re: SystemModelGroup for variable
    Hello Bernhard,
    Your code works fine. Thank you very much.
    Dmitry
    You are welcome
  1. Replies: 4
    Last Post: 11th March 2019, 16:26
  2. Replies: 1
  3. Replies: 1
