Thread: Activate a button in VSTA (to Acquit alarms)
    20.01.2015
    18
    Default Activate a button in VSTA (to Acquit alarms)
    Hey,
    Is it possible to activate a button in VSTA ?
    I want to acquit all alarms in another synoptic (normal type).
    Even if there is another way to acquit alarms, I'm still interrested to know how to activate a button in VSTA !
    Varnizy Loan.
    Default AW: Activate a button in VSTA (to Acquit alarms)
    by "Activate" you mean you want to "Simulate" the click of a user on a button?
    If yes, the only way to do that is to create a script in zenon containing the following 3 functions:
    - set focus on frame (the frame where your screen containing the button is based on)
    - move focus (on your button)
    - activate element with focus
    then creating a script execute function with this script and calling this function in VSTA (via RtFunctions().Item("MyScriptExecuteFunction").Start())
    881
    Default Re: Activate a button in VSTA (to Acquit alarms)
    you can direct execute the function "Alarms: acknowledge" via the zenon API
    -> create the standard function in the editor (configure it to your needs)
    -> via the zenon API (in the zenon Runtime) you execute the function - via the method .Start()
    -> see help documentation at Manual -> Programming interfaces -> Objectmodel -> RtFunction -> RtFunction-Methods -> Start
    doing so it is not necessary to have the AML screen opened in order that a certain function linked to a button should be executed...
    regards,
    herbert
    20.01.2015
    18
    I looked at functions but I missed the Alarms tab haha !
    Sorry for that!
    Thanks for this complementary answers!
    Varnizy Loan.
  1. Ghost Alarms
    By synergyautomation in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 18th December 2014, 14:52
  2. Activate Frame
    By dario in forum VBA
    Last Post: 26th April 2013, 09:29
  3. Replies: 1
    Last Post: 13th March 2012, 12:13
  4. Backfilling alarms
    By sldewit in forum VSTA
    Last Post: 21st July 2010, 00:00
  5. number of alarms
    By hicom in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 25th June 2009, 05:33
