Thread: Delete item in a combobox
    17.12.2007
    35
    Default Delete item in a combobox
    Hi
    During project configuration VBA "fill" a combobox in this way.
    Set zPIC = zPRJ.DynPictures.Item("Layout.Top")
    zPIC.Elements.Item(2).CreateDynProperty ("States[" & CStr(IndexObj) & "]")
    zPIC.Elements.Item(2).CreateDynProperty ("States[" & CStr(IndexObj) & "].Text")
    zPIC.Elements.Item(2).DynProperties("States[" & CStr(IndexObj) & "].Text") = Group
    zPIC.Elements.Item(2).CreateDynProperty ("States[" & CStr(IndexObj) & "].Value")
    zPIC.Elements.Item(2).DynProperties("States[" & CStr(IndexObj) & "].Value")=IndexObj
    zPIC.Save
    Everything is ok.
    My question is : always through VBA is possible to delete an extension of a combobox?
    Thanx
    robertf Gast
    Default Re: Delete item in a combobox
    Hello!
    It is not possible to delete "DynProperties".
    So you may have to save the actual configuration of the element.
    (Position, Font, Color, Combobox-Entries, ...)
    Then you can delete the Element and create a new one with the saved information.
    I this doesn't answer your question, then let me know...
    17.12.2007
    35
    Thanx ...
    you answer ....this was my "B option"
  1. Accessing the rgm recipe name combobox
    By andreacold in forum VBA
    Last Post: 24th February 2014, 14:35
