Thread: Alarm Variable Authorizatiion
    01.08.2014
    13
    Default Alarm Variable Authorizatiion
    I want add authorization for acknowledging the alarm variable. I have searched for adding authorization to the variable but i couldn't find it. Please Help me.
    Thanks & Regards,
    Vishnuteja
    879
    Default Re: Alarm Variable Authorizatiion
    In the zenon Editor select the project in the tree, then
    - User administration -> Function authorizations -> Function authorizations Runtime
    see also help documentation at
    Manual -> User administration -> Engineering in the zenon Editor -> Function authorizations -> Function authorizations Runtime
    regards,
    herbert
    01.08.2014
    13
    Dear Herbert,
    I have created users in user administration and given them different authorization levels.While alarm acknowledgement of some variables only a particular user should be able to acknowledge while other users can't acknowledge.
    Can you please guide me that above solution given by you related my problem.
    Thanks & Regards,
    Vishnuteja
    879
    it is not possible to have different authorization levels on certain alarms.
    what you can do is to make i.e. alarm groups which you then use as filter for the alarm message list (AML). so that then a certain user can only see certain alarms in th AML (and can acknowledge them) whereas i.e. an adminstrator can see all alarms (and can acknowledge them) - the preselecting of the alarm groups is done then in the screen switch function to the AML.
    have a look into the help documentation at following chapter:
    Manual -> Alarms administration -> Configuring alarms -> Grouping of alarms
    regards,
    herbert
  1. Replies: 5
    Last Post: 8th October 2014, 13:47
  2. Set variable alarm group
    By davide.galigani in forum VBA
    Last Post: 11th June 2014, 19:42
  3. alarm status from variable
    By westbaaam in forum VBA
    Last Post: 7th October 2009, 05:43
  4. Status variable for alarm areas
    Last Post: 24th February 2009, 09:56
  5. Alarm Status Line and Alarm List
