Showing results 1 to 7 of 7
Thread: Adding IEC850 driver variables in CEL
    01.08.2014
    13
    Default Adding IEC850 driver variables in CEL
    hi,
    I want to display IEC850 driver variables in chronological event list(CEL) when there is change in the value. Is there any way to display the variables in the CEL without setting the flag of 'Chronological Event List' in the 'Limit' section of the variable.
    Vishnuteja
    Default AW: Adding IEC850 driver variables in CEL
    usually such a scenario is addressed by archiving (on value change).
    There is a setting at the variable: Set value -> Logging -> All, but this only logs Set value actions/changes via the API.
    You could also create an online container in the API and write cel entries in the ValueChangeEvent but I don't know if this is the best solution for your scenario.
    16.07.2014
    Zaporizhia
    43
    Default Re: AW: Adding IEC850 driver variables in CEL
    Using Reaction matrix instead of limits in each variable?
    Default AW: Re: AW: Adding IEC850 driver variables in CEL
    Quote Originally Posted by diemon View Post
    You are right, this should work and would be the best solution!
    01.08.2014
    13
    no reaction matrix can't be used because for some variable i have used limits. I have bool and integer variables. And i have approximately 5000 variables.
    16.07.2014
    Zaporizhia
    43
    Quote Originally Posted by nvishnuteja View Post
    Friend, i have 5600 iec850 variables.... (Current, Voltage, etc. protections, a lot of switches...), and use limits in each variables.
    Or limits, or REMA. no other ways, i think
    955
    Default Re: Adding IEC850 driver variables in CEL
    hi nvishnuteja,
    Archiving of variable values mentioned by bernhardf you can find in node 'Historian'. The data is then stored in additional files, not in CEL. To access this data you can use screen type 'Archive revision' (nice for reports and for exporting into other tools) or 'Extended Trend' (nice for measured values, e.g. to follow changes of V or A or Hz).
    Reaction matrix mentioned by diemon can store data in CEL: you can create a single ReMa as 'Multi numeric' with one state - for 'Value' = 'Any', with activated 'Treat each change of value as new limit violation' and 'in Chronological Event list'. Then you can multi-select all variables you want and with one click you can link all these variables with the same ReMa (variable property 'Limit values' - 'Reaction matrix').
  1. IEC61850 Driverconfiguration messed up after adding a driver
    Last Post: 22nd January 2016, 11:29
  2. Replies: 0
    Last Post: 22nd June 2010, 09:02
  3. question IEC850
    Last Post: 10th December 2009, 07:41
  4. Importing variables for the IEC870 driver is hanging
    Last Post: 10th December 2007, 13:51
  5. Replies: 0
    Last Post: 19th September 2007, 11:06
