Thread: The file zenon6.ini in version 7.10 for CE does not contain the SERIAL7 entry.
    18.02.2014
    22
    Default The file zenon6.ini in version 7.10 for CE does not contain the SERIAL7 entry.
    The file zenon6.ini in version 7.10 for CE (all versions : 600 and 500 and x86 and ARM) does not contain the SERIAL7 entry.
    When you start zenonRCE.exe there is a dialog bow that opens with this message:
    "The program cannot be started, because there is no valid serial number available.
    Please open …zenon6.ini and enter a valid serial number in the key:
    [DEFAULT]
    SERIAL7="
    18.02.2014
    22
    Default Re: The file zenon6.ini in version 7.10 for CE does not contain the SERIAL7 entry.
    Due to compatibility reasons, it is unfortunately not possible to re-develop afterwards the setup file. The Setup file also includes the affected zenon6.ini.
    For later versions (after 7.10) this behaviour has been corrected. The missing Serial7 entry was added to the zenon6.ini.
    Possible workaround for 7.10: To type-in manually the Serial7 into the zenon6.ini.
  1. [Zenone 7.10] Zenone32 / Error: 100 / zenon6.ini
    By vero in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 21st April 2020, 11:55
  2. SIMUL32-Einträge in zenon6.ini
    By michab in forum Drivers
    Last Post: 6th August 2013, 00:34
  3. Variable reaction matrix's limit text entry
    By dario in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 7th May 2013, 06:59
  4. Advantage of ZenOn Energy version versus Standard version?
    Last Post: 23rd June 2011, 23:54
  5. Zenon6.ini Windows sbs
    By rloureiro in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 6th June 2008, 17:14
