Thread: Add Variables with C# to Zenon (Editor-Mode)
    09.03.2015
    34
    Default Add Variables with C# to Zenon (Editor-Mode)
    I am searching for a solution to add variables with C# to an open Project in the Zenon Editor.
    I am currently using the following code...
    this.zVariable = this.zProject.Variables()
    .CreateVar(psVariableName, null, tpKanaltypes.tpSystemVariable, GetDataType("STRING"));
    But I cannot see the created Variable in the Zenon Editor?!
    What's wrong?
    Regards...
    13.08.2013
    57
    Beitrag Re: Add Variables with C# to Zenon (Editor-Mode)
    Hi Nollh,
    you are missing the drivertype
    try something like this, I solved it with an extension method, but you always can do it with a "normal" method
     public static zenOn.IDriver InternalDriver(this zenOn.Project pProject)
                for (int i = 0; i < pProject.Drivers().Count; i++)
                    if (pProject.Drivers().Item(i).Name == "Intern")
                        return pProject.Drivers().Item(i);
                return null;
    public void createVar()
    .CreateVar(psVariableName, this.zProject.InternalDriver(), tpKanaltypes.tpSystemVariable, GetDataType("STRING"));
    Best regards
    Sigi
    09.03.2015
    34
    Default Re: Add Variables with C# to Zenon (Editor-Mode)
    Thanks for your help!
  1. Can not restore a *.prj file from the zenOn Explorer with the zenOn Editor
    By kyle_lee in forum zenon Service Engine Supervisor
  2. Add a variable type 'byte'
    By martijnvanspijk in forum Drivers
    Last Post: 28th May 2013, 11:00
  3. Add element to zenOn ListBox
    By fabios in forum VBA
    Last Post: 30th November 2012, 15:30
  4. Zenon 6.51 license vs. Demo mode
    By rbfernandez in forum zenon Service Engine Operator
    Last Post: 30th November 2012, 08:45
  5. Replies: 0
