Thread: How to deploy .NET Activex
    01.10.2014
    26
    Default How to deploy .NET Activex
    I have developed an activex in Visual Studio 2012 and I want to deploy it. If I build the project in local machine where I have develoed the control every thing is ok and it works ok. But if I make a installer for it and install the activex control on Targer machine I can't see the Activex in the list of Activex to use it in zenon.
    Should set a special properties in Setup project?
    I send the configurations which I have used for my activex. But it doesn't work!
    Parisa
    Default AW: How to deploy .NET Activex
    Quote Originally Posted by parisamoosavi View Post
    Parisa
    what exactly does the installer do?
    You could try to register the ActiveX control manually by registering it via a RegAsm call like this:
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Re gAsm.exe "D:\myControl.dll" /codebase
    C:\Windows\Microsoft.NET\Framework\v4.0.30319\RegA sm.exe "D:\myControl.dll" /codebase
    PS:
    Be sure that the zenon Editor & zenon Runtime is closed during the registration process!
    01.10.2014
    26
    Because I have some dlls which are developed in .Net and I wanted, the end user only through a click installs all of them.
    To register the dlls I have followed the IU-17,Page 26 and I used regasm.exe dll-name.dll /tlb:dll-name.tlb but it couldn't help. But with /codebase I could register the dll manually.
    I appreciate it.
    Parisa
    Parisa
    You can still do this by creating a small application which registers the controls for you (That's what I did for testing purposes).
    For more detailed information on the /codebase parameter see here:
    https://msdn.microsoft.com/de-de/lib...vs.110%29.aspx
  1. .NET Framework version
    By loanvar in forum VSTA
    Last Post: 11th June 2018, 07:54
  2. VB .net program
    By twilight in forum VSTA
    Last Post: 27th June 2014, 09:02
  3. Benutzerübersicht VB.net
    By and12121 in forum VSTA
    Last Post: 3rd March 2014, 15:31
  4. WPF with .Net
    By dlamarche in forum VSTA
    Last Post: 4th July 2013, 02:55
