Thread: Web Client Error
    08.12.2013
    27
    Ausrufezeichen Web Client Error
    I've faced error when connecting web client to web server.
    Error message as attached, .cmp missing, unsuccessful transfer to web client.
    Any advise?
    25.06.2012
    155
    Default Re: Web Client Error
    Hello yitlilee,
    Have you already search for similar topics in the forum? Please use the search tool as you can find more information about the message you are reporting. For example, try to use the words "webclient start".
    If still you cannot find the solution after searching in the forum, please post again.
    David Cerdeira
    14.11.2014
    Sweden
    8
    Quote Originally Posted by yitlilee View Post
    Any advise?
    I found that Chrome does'nt support the Webclient that well.. Try using IE (AND ADD WEBSITE TO TRUSTED WEBSITES) and see if it works better.
    20.08.2009
    293
    Default AW: Web Client Error
    Any advise?
    - Is your connection from WebClient <-> WebServer <-> RuntimeServer valid (check with pings)?
    - Is your project configured as a network project?
    - Are Server and WebServer up and running?
    - Did you build the "Runtime changeable data" files for this project?
    Quote Originally Posted by henrixon View Post
    What exactly does not work with Chrome?
    Chrome (as well as Safari and Firefox) is supported since version 7 and the Webclient should act the same as in the Internet Explorer.
    Bernhard
    14.11.2014
    Sweden
    8
    Default Re: AW: Web Client Error
    Quote Originally Posted by bernhardf View Post
    Bernhard
    Im sorry, I think I'll have to take that back, after further testing it seems that the problem wasn't the browser but my configuration.
    /NIXON
    Sith Lord @ Omexom Sweden
  1. Web Client mehrmals am gleichen PC
    By herrmoartl in forum Webserver/Webclient
    Last Post: 2nd May 2014, 09:25
  2. Web Client
    By gyu in forum Webserver/Webclient
    Last Post: 4th March 2014, 08:27
  3. zenon Web-Client 7 -> Web-Server 6.22 slow startup
    By kicker in forum Webserver/Webclient
    Last Post: 24th September 2013, 21:11
  4. Web client subprojects error
    By jurijcadez in forum Webserver/Webclient
    Last Post: 17th May 2012, 23:34
  5. Web client VBA
    By jurijcadez in forum VBA
    Last Post: 15th May 2012, 14:43
