Thread: the standard user "SYSTEM"
    Default the standard user "SYSTEM"
    Hi all,
    It is possible to change the standard name of the default user "SYSTEM" in zenOn (6.22 SP0) ?
    Is there any solution ?
    I'll try with the function "Language change" but don't work..
    Best regards, Roberto
    Default Re: the standard user "SYSTEM"
    Because the SYSTEM user is a build in zenon user, there is no possibility to change its name. This user indicates that currently no user is logged in and only elements which requires only the Authorization level 0, can be operated.
    The language switch does not work in this case because there is no keyword present within the project itself.
  1. Replies: 2
    Last Post: 9th June 2009, 12:53
  2. action "COMMAND" at the dynamic element not visible
    By markclemens in forum zenon Energy Edition
    Last Post: 16th May 2008, 06:53
  3. system variable "last open picture"
    Last Post: 7th April 2008, 13:50
  4. Replies: 2
    Last Post: 3rd April 2008, 12:24
  5. "prepare this blank disc" message when inserting 6.22 DVD
    By markclemens in forum Editor and Runtime Setup
    Last Post: 21st February 2008, 13:43
