Thread: SetValueWithStatusEx restriction in VBA 7.11?
    Default SetValueWithStatusEx restriction in VBA 7.11?
    Hello support team.
    After switch to 7.11 our old project's VBA code cannot be compiled with selection of SetValueWithStatusEx function and shown an error message:
    Function or interface marked as restricted, or the function uses an Automation type not supported in Visual Basic.
    In help file I found no information about any restrictions of SetValueWithStatusEx function.
    Can you clarify this?
    Andrey
    Default Re: SetValueWithStatusEx restriction in VBA 7.11?
    Also interesting moment:
    When I start in 7.11 VBA to type
    var.SetValueWithStatus(
    VBA shows me list of possible parameters.
    In case of typing var.SetValueWithStatusEx(
    it doesn't happen..
    7.11 build 11206
    Andrey
    880
    Default AW: SetValueWithStatusEx restriction in VBA 7.11?
    is it possible that you have created a own function/method named with "SetValueWithStatusEx" ?
    Hello, herberto.
    No, in my project there are no such entries.
    Andrey
  1. Replies: 3
    Last Post: 27th October 2011, 09:58
