Thread: Printer Select......
    30.07.2014
    23
    Lächeln Printer Select......
    When trying to select a printer in run time i get the attached error?
    I have printers installed on the OS.
    Any clues as to what this blank error is... ;-) .?
    thanks
    SA
    30.07.2014
    23
    Default Re: Printer Select......
    I should add that this is on pressing the "..." button to the right hand side. I can select the printers from the drop down fine. just curious as to what this message is as i know the customer will not like blank messages.... ;-)
    09.03.2011
    44
    Dear synergyautomation,
    You must select which printer you want to use in zenon. You can do that in the menu File --> General Configuration --> Standard.
    You can find more information about printer configuration in the zenon help: Manual -> Project and workspace -> Configuration -> Standard -> Printer
    Estefanía.
    30.07.2014
    23
    Hi Estefania,
    Thanks for the reply.
    So this si working fine but the customer required to be able to print a report (working) or save it as pdf. This i was using PDFCreater and was also working but now they have to switch between the printers first.
    Is there a way to switch between printers without the dialog box?
    So they can just hit the "PDF" Button and a pdf is produced or hit the "Print" button and a page is printed?
    SA
    18.02.2014
    22
    You have several functions for exporting and printing reports. Take a look on that specific functions for "Report Generator / Report Viewer / Analyzer"
    For Report Viewer i.e. you have the function "Report Viewer: export / print.
    By configuring the function you can define the output of the Report. If you need it as PDF (saved on a defined location) or if you want it to print out.
    By a button linked with the pre-defined function you can execute a print of the Report or save as PDF directly.
    TAH
  1. Select and Select before operate
    Last Post: 22nd January 2016, 11:12
  2. Select objects in Runtime to create a graph
    By dario in forum zenon Service Engine Supervisor
    Last Post: 15th January 2013, 03:17
  3. Printer Selection
    By tanveerali in forum zenon Service Engine Supervisor
    Last Post: 13th August 2011, 11:30
  4. Select trend profile from VBA
    By mvj in forum VBA
    Last Post: 2nd December 2009, 09:46
  5. How to set the printer in Runtime
    By dragosmoss in forum zenon Service Engine Supervisor
    Last Post: 24th May 2009, 19:00
