Thread: Disable Element.....
    30.07.2014
    19
    Default Disable Element.....
    So if I was using vb.net i could just do
    btnLogin.Enabled = False
    This would grey out the button and not let the user click on it.
    Is there the possibility for this? I thought i could just put a rectangle over the top of the element in question with a 50% transparency and link its visibility to specific user level - this works but i can still click the button underneath the rectangle.... ;-)
    30.07.2014
    19
    Default Re: Disable Element.....
    So I have done this now with an button. Transparency set to 50%. Note - you have to link the button to a variable/function or it will still allow you to click the button underneath....
    Maybe there is a more elegant way?
    Default AW: Disable Element.....
    when should this button be disabled?
    Why dont you use the interlocking/authorization level property of the button?
  1. Disable double right click acknowledge
    Last Post: 29th April 2016, 07:58
  2. Alarm limit enable/disable
    By fatih.oz in forum zenon Supervisor
    Last Post: 29th January 2015, 09:02
  3. Disable grid lines in trend XY
    By galax in forum zenon Supervisor
    Last Post: 3rd April 2013, 09:42
  4. There is a way to disable monitor assign function
    Last Post: 25th October 2009, 07:40
  5. How to disable click sounds on virtual keyboard
    By balzse in forum zenon Operator
    Last Post: 8th October 2008, 09:06
