Thread: Trending Diagram Error - C0000005 ACCESS_VIOLATION
    29.01.2015
    10
    Default Trending Diagram Error - C0000005 ACCESS_VIOLATION
    Hi ,
    There is an error pop up when click on the "diagram" button in the trending screen.
    Unhandled exception:
    C:\ProgramData\COPA-DATA\zenon711\zenrt32.txt
    C:\ProgramData\COPA-DATA\zenon711\zenrt32-7.11.0.10238(0)-20150129-105922-DT0000.dmp
    In Zentr32.txt:
    1/29/2015, 10:00:57 AM
    zenOn Version: 7.11 SP0 Build10238
    MS Windows Ver. 6.2.
    Processor: UNKNOWN
    Exception code: C0000005 ACCESS_VIOLATION
    Fault address: 7FDB4DF028F 01:0027F28F C:\Windows\SYSTEM32\mfc110u.dll
    Please help on this problem. Thank you.
    879
    Default AW: Trending Diagram Error - C0000005 ACCESS_VIOLATION
    Please contact your local Copa-Data support - they will assist you in this case.
    FYI: the effect which you describe should not appear anymore on installing the latest BuildVersion of zenon 7.11 (BuildVersion Setups are only forwarded from the local Copa-Data support)
    regards,
    herbert
  1. Trending display with variable identification
    By yitlilee in forum zenon Operator
    Last Post: 19th December 2013, 15:27
  2. Runtime Error C0000005 Access Violation
    By tomhul in forum zenon Supervisor
    Last Post: 30th August 2012, 01:51
  3. Trending
    Last Post: 29th April 2010, 05:17
  4. XY diagram
    Last Post: 4th January 2010, 23:44
