Thread: Relays Offline In Runtime
    06.12.2014
    3
    Default Relays Offline In Runtime
    Dear Support,
    We are using DNP3-Process gateway over serial communication. Our network include 50 relays out of which 3 relays are showing offline on Gateway Runtime. In actual Relay is reachable(pingable) and from other workstation on the same network it shows online on Zenon Runtime. The only problem for these 3 relays are on Gateway Runtime.
    Please suggest what could be the possibilities for this problem.
    Default Re: Relays Offline In Runtime
    Hi junaid,
    I'm not exactly sure what you mean with "appear offline in the gateway".
    You say, you have a zenon runtime with a DNP3 process gateway, using serial communication. I assume, that you have a single gateway running, which is a DNP3 outstation with a certain DNP address.
    Then you have a serial DNP3 master, that is communicating with the DNP3 outstation in the process gateway.
    Where exactly do you see that 3 relays are offline? And why do you think they are offline?
  1. Printing offline CEL/Alarm List
    By prokopjev in forum zenon Supervisor
    Last Post: 5th December 2013, 14:01
  2. Printing offline CEL/Alarm List
    By ionvalesareanu in forum zenon Supervisor
    Last Post: 22nd February 2012, 14:25
  3. User column in events offline printing
    By shahrzad in forum zenon Supervisor
    Last Post: 2nd March 2011, 09:25
  4. Analog Values with GE Relays
    By janlyndon in forum zenon Supervisor
    Last Post: 16th May 2010, 22:54
  5. Online and Offline printer
    Last Post: 24th August 2009, 23:08
