Thread: Size and Rotation Dynamic - CE
    30.07.2014
    19
    Default Size and Rotation Dynamic - CE
    Hi all, so I understand the the Size and Rotation Dynamic for a drawing object is not possible under Windows CE, so i ask is there a way to do this that is possible under Windows CE project?
    Basically i need to change the width of a rectangle based on the value of a variable. Not too tricky!
    David
    14.07.2010
    46
    Default Re: Size and Rotation Dynamic - CE
    Hallo David,
    as mentioned in the help documentation:
    Manual -> zenon Operator -> Restrictions for the zenon Operator -> Special restrictions for the CE version
    Dynamics such as rotation, changing height and width or X and Y position are not available
    There does not exist any workaround.
    Daniela.
    30.07.2014
    19
    Thanks, I had seen the document but hoped there was a work around.
  1. How to size a Dynamic Text Box
    By pilzfrance in forum zenon Supervisor
    Last Post: 10th March 2014, 02:26
  2. Rotation not possible on CE
    By yzhyff in forum zenon Operator
    Last Post: 7th March 2014, 09:56
  3. Size dynamic for ActiveX and Control Elements
    Last Post: 12th December 2013, 11:34
  4. zenOn 6.21 Size of the ringbuffer
    By cypress329 in forum zenon Supervisor
    Last Post: 22nd February 2011, 05:55
  5. Rotation on Windows CE
    By mattsd in forum zenon Operator
    Last Post: 23rd October 2007, 10:38
