Thread: PCE stopped working after license was installed
    24.11.2009
    Default PCE stopped working after license was installed
    I have some scripts programmed in PCE and they were working fine in Demo mode. As soon as i put license numbers and activation code. Visual basic scripts made in PCE stopped working. All other stuff seems to be working without any problem.
    Is it wrong license? Or could it be because of wrong generated textfile from licensing tool?
    Thanks,
    Marek
    martins Gast
    Default Re: PCE stopped working after license was installed
    hi,
    what happens if you try to remove the license again and start up with the demo license?
    best regards,
    Martin
    24.11.2009
    Quote Originally Posted by martins View Post
    hi,
    best regards,
    Martin
    Its working with demo license. I'm pretty sure it is license issue. Even when runtime is starting, in loading window there are name of the modules(i suppose, it is showing available modules for current serial number ) and "Process Control Engine" is missing there(when demo license is used, it is showing it and it is running).
    Question is, if i can add this module to de license?.
  1. PCE- Function VBS
    By luisier@altherlamon.com in forum VBA
    Last Post: 28th July 2014, 15:46
  2. How to installed Zenon5.50 sp7
    By lalitsharma2709 in forum Editor and Runtime Setup
    Last Post: 6th October 2013, 23:26
  3. PCE or ms in VBA
    By westbaaam in forum VBA
    Last Post: 6th November 2009, 07:44
  4. PCE on WinCE 5
    By consol in forum zenon Operator
    Last Post: 24th June 2008, 10:52
  5. Start Function From PCE
    By stephanepilon in forum VBA
    Last Post: 16th May 2008, 06:33
