Thread: Copying a string to another string
    26.02.2014
    36
    Default Copying a string to another string
    I have a Zenon SCADA and there are two strings on screen, current batch and previous batch. The user needs to type in a description of the current batch. When the batch ends, a bit is set on by the PLC. This will trigger a copy of the Current batch string to previous batch string, however I can't find out how to do it. I have tried an allocation, but it seems that you can't do an allocation with a string as source, although strangely enough, it lets you create one, it just doesn't work. As the PC has a licence for Recipegroup manager, I tried to do the copy using a recipe but this doesn't work either. Is it the case that read/write of a recipe only works on a user action, like a button press, not a bit change? I'm not sure. Anyway, the main question is this, How can I copy the value in one memory string variable to another whenever the PLC sets a bit?
    26.02.2014
    36
    Default Re: Copying a string to another string
    I now have the solution to this problem. I have a network system and the internal variable setting on the strings was set to local. Changing the setting to network resulted in the string copy allocation working correctly.
  1. Reaktionsmatrix / String
    By poe_79 in forum zenon Supervisor
    Last Post: 31st March 2014, 08:05
  2. String in Byte-Array
    By rooswald in forum Drivers
    Last Post: 21st May 2013, 07:31
  3. String length field for STRING variables.
  4. String Input
    By acko01 in forum zenon Supervisor
    Last Post: 10th March 2011, 00:02
  5. String/text display
    Last Post: 19th March 2009, 09:10
