Thread: PLC Variables and Internal Variables
    madphilly Gast
    Frage PLC Variables and Internal Variables
    I have a Mitsubishi Data Register variable that holds the value of a count, in an allocation I want to allocate this variable value to an Internal Variable, then later allocate it back. It doesn't seem to work!
    Both datatypes are INT.
    Is it possible to do what I am trying to do?
    Default Re: PLC Variables and Internal Variables
    yes, normally this should be possible.
    Are you using an allocation for this? There are two types of allocations in zenon. Spontaneous allocations and triggered allocations. If the variable linked at the source changes, the variable at the target is written, and receives the timestamp of the change.
    If you have linked a trigger variable in addition to the source and target variable, the allocation is exectuded either when the trigger variable is "1" or alternatively on the edge.
  1. Standard Recipe and string variables
    By flajoso in forum zenon Service Engine Supervisor
    Last Post: 5th May 2008, 09:43
  2. SQL variables allocation problem
    By rloureiro in forum Drivers
    Last Post: 13th March 2008, 13:32
  3. changing object colour from multiply variables
    By mattsd in forum zenon Service Engine Supervisor
    Last Post: 12th November 2007, 02:09
  4. Help! I can not import my variables .dbf file
