Thread: Math functions not working on network system
    26.02.2014
    36
    Default Math functions not working on network system
    I have a system with a network. The master PC communicates to the PLC but the User runs the Zenon on the local PC. Math functions only work if the variables are I O.
    For example I have a math function with a bool output X01 > 13
    This works if X01 is a PLC I O variable but not if it is an internal variable, it always gives false even if the variable is greater than 13. Is this because the application is networked?
    And how can I get the math function to work correctly on an internal variable?
    765
    Default Re: Math functions not working on network system
    Change by internal variables the property Calculation from 'Local' to 'Network'.
    In general - when you are using zenon Network, set by all internal variable calculation to 'Network'. The setting 'Local' is suitable only by variables which should have different values pro PC.
    26.02.2014
    36
    That has worked. Thank you for your help.
  1. Multiple selected math variables formula editing issue
    Last Post: 31st October 2014, 21:43
  2. Math variable doesn't work on client
    By andrey_k in forum zenon Network
    Last Post: 19th March 2014, 11:40
  3. Math-Var: Zugriff auf Unterprojekt-Variablen
    By stessl666 in forum zenon Supervisor
    Last Post: 20th December 2011, 16:00
  4. Network Project
    By fafdaniel in forum zenon Network
    Last Post: 5th October 2011, 23:33
  5. Priority of operators for Math driver?
    By lephis in forum Drivers
    Last Post: 4th October 2010, 13:23
