Thread: PDiag import into zenOn
    craigh2 Gast
    Default PDiag import into zenOn
    I'm trying to import my PDiag data from S7 into zenOn. I read the documentation provided with the zenOn installation disk regarding PDiagConverter but I cannot find this program anywhere in the zenOn software. I see an item in the "Options" menu to import S7 PDiag, but it is disabled and I have no information on how to enable it. What steps do I need to follow to get my PDiag information into zenOn? Any help would be appreciated.
    Thank you,
    Craig
    Default AW: PDiag import into zenon
    hello craigh2,
    I can give you some information for importing of pdiag messages into zenon.
    I have create a wizard for our german customers which you can use.
    This wizard have (now) a optional english user interface so you can use it.
    In this wizard is a short help which showns you the steps to do.
    1. In simatic manager create your pdiag messages. After compile the messages you have to export this into a csv file. Please select file-type = csv.
    2. Now you have to import this file with the wizard.
    that's all...
    When you have change the step7 / plc program you have to import the messages again...
    For your information:
    1. This wizard imports only pdiag "address monitoring" and "general monitoring"
    2. This wizard do not support "assoc. values"
    3. This wizard do not support "formal operand" like "@1X4d@"
    4. If you want that the wizard only shows a english interface you can change this in the code. In the "Private Sub UserForm_Initialize()" you must change "deutsch = True" to "deutsch = False"
    Default Re: PDiag import into zenOn
    in this reply you find the actual version of the zenon PDiag import wizard.
    This wizards imports an exported PDiag file in XML format.
    04.08.2011
    49
    Quote Originally Posted by berndwimmer View Post
    hello craigh2,
    that's all...
    But the PDIag Wizard supports only XML file. Is there an other way to import messages?
    Or it's possible to generate the XML file by my own?
  1. Export And Import of XML
    Last Post: 24th April 2008, 07:44
  2. rapidly creating Zenon functions using import/export
    Last Post: 10th January 2008, 10:20
  3. Help! I can not import my variables .dbf file
  4. Replies: 0
