Thread: Simple VB in Zenon
    26.02.2014
    36
    Default Simple VB in Zenon
    I have used Zenon for projects, but never Visual Basic. All I need to do is write simple VB scripts which will assign a value to a variable, or a variable value to another variable, for example to set VariableA = 1, or VariableA = VariableB. I have tried some tests, but they do not work.
    I know very little of VB, is there a manual or instructions for beginners (specifically relating to VB in Zenon) that I can find online, or maybe someone can post a guide on how to make this simple script.
    martins Gast
    Default Re: Simple VB in Zenon
    hey,
    usually, allocations would be sufficient to what you need - assigning a value from one variable to another one.
    If you need something more complex and you are familiar with PLC programming, it sounds like zenon Logic would be the perfect tool for you
    In the help under Manual - zenon Logic, you can find some information how to start with zenon Logic. By writing your own IEC61131-3 compatible programs, similar to how you are used to it in a PLC
    best regards,
    Martin
    26.02.2014
    36
    I considered allocations, but I need over 200 of them. I am hoping that using VB would be easier than creating so many allocations.
    20.08.2009
    293
    Default AW: Simple VB in Zenon
    first you have to ensure that the variables you want to read are advised. Therefore you can create an OnlineContainer, see here (first post) or search the forum for OnlineVariables.
    Then you can write code like this:
    thisProject.Variables.Item("VariableTarget").Value = thisProject.Variables.Item("VariableSource").Value
    Again please search the forum for additional info on reading/writing variables.
    Bernhard
    Edit:
    zenon Logic as Martin suggested would be also my favourite option (then you don't need to take care of the advising and it's way more error prone.
    30.05.2007
    Salzburg
    879
    -> you can create those variable allocations programmatically
    -> see help documentation at Manual -> Programming interfaces -> Objectmodel -> VarAssignments
    Using variable assignments you also dont have to care about if a variable is advised or not. Also if you rename your variable - zenon do this internally for you (which is not the case if you do this programmatically).... aso...
    To give you an advise about programming in zenon:
    - for engineering within the zenon editor you can save many working hours
    - within the zenon runtime you have to take care because if there is error within that code (or other certain situations) it will directly influence the behaviour of the zenon runtime - which will probably lead to extra working hours.
    regards,
    herbert
    26.02.2014
    36
    I am not sure what you mean by advised. Is this something that you need to do to a variable?
  1. Simple Project, no idea
    By matholton in forum zenon Supervisor
    Last Post: 24th September 2008, 12:01
